Gdetrailer
Aug 21, 2022Explorer III
Glad you are getting that worked out!
The last aftermarket stereo I installed was in my 2013 F250, was able to integrate fairly easily with just the normal wiring adapters and a module for the steering wheel controls and normal cheap aftermarket front plate. I did have to dig around the fuse box to find a key switched power source.. For removed that from the wiring harness in favor of using CANBAN bus data to tell radio to power on/off..
Fast forward to 2019, aaaaand they went the stupid direction of the entire center stack including heat/AC controls 100% factory integrated.. $300 for a aftermarket center stack face plate and I would have to relocate the heat/AC controls onto the aftermarket plate.. Then to get rear camera requires another $300 for a module, then a another module to get the steering wheel controls.. More money for the wiring harness adapters and then the stereo.. I would lose the outside thermometer reading as that is integrated into the factory radio display..
The ultimate insult is Ford has intentionally hobbled the sound quality by filtering out much of the bass frequencies as you turn up the volume.
All in would cost $1,500-$2,000 to get a far better sounding stereo..
There are some aftermarket digital sound processors which can be adapted to the speaker outputs to restore the bass but then you must either hack the wiring or find some plugs that fit and then add new more powerful amps.
If and when the factory stereo bites the dust, I will pin a aftermarket stereo in a little cubby at the bottom of the center stack and run new wiring.. What a waste of space just to prevent folks from obtaining a better stereo quality..
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
