clikrf8's avatar
clikrf8
Stereo receiver to avoid voltage drop
I know someone out there has a solution to this issue. We often camp off grid, that is, solely using 140 watts solar and 2 AGM batteries (Deka) rather than 30 amp shore power. We have a factory installed Magnadyne Linear Series RV5055 AM/FM stereo Multi-media Receiver. We will turn it on after we set up for the night and after a few hours or less it will shut itself off or intermittently come back to life then cut out again. I called the toll free number and actually got a real live person who confirmed what we thought: voltage drop. Fully charged, we are at 14 (volts or amps, I am a right-braainer so techy stuff makes my head spin). We rarely go below 12.5. The guy at Magdadyne said that it should be powered into the 11s. But, he also said that even though our controller or whatever gives the readouts, is actually in the 11s due to something which I didn't understand.
I have been looking online for answers and don't really understand what is being said. Can someone here provide a clearer picture of what is happening and how to remedy it?
Should we get THIS ?
I am looking at marine systems also because of our PNW weather (dampness) and we would like NOAA weather channel (used it all the time when fishing SE Alaska in the 70s). I found this on THIS or a similar one with less wattage?
Our equipment that draws power:
Hallmark Power roof lift system (a motor like MRIs use )- just takes a minute or two to raise and lower
NovaKool Compressor fridge (4+ Cubic feet)
all LED interior lights
Atwood 17,000 watt heater
Fantastic fan
Power equipment:
140 watts solar
Blue Sky Solar Boost 2000E charge controller
ProWAtt SW SW Sine Wave Inverter
2 DEKA 12 volt batteries.
Any help out there? Should we work with what we have or get another model that draws less power? We like our music and don't crank it up.
Thank-you and Happy Thanksgiving!!!!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
