- MPI_MallardExplorerI have the Tire Minder Systemclicky on both my truck and fiver' and it works very well also they have a battery trade-in sysem plus their customer service can't be beat,i'd recommend them to anyone!!!
- fj12ryderExplorer III
peaches&cream wrote:
Don't feed the troll. Anyone who posts a leading statement like that is trying to do some pot stirring.JaBob wrote:
Buying one was my biggest mistake ever.
Would you please elaborate on this statement? I have found customer service to be great at TST. Cannot imagine why you feel it is the "biggest mistake" you have ever made. And you live very close to the source of supply. Did you go over there screaming and holloring and they threw you out of the office? If it was installation problems, maybe you lack the knowledge of self installing the unit. Like I said in a previous post, mine has worked well for 6 yrs. I have had sensors batteries go dead, and even had one sensor leak, but I replaced the problem ones and moved on. Feel much safer on the road with my system working than without it. - peaches_creamExplorer
Would you please elaborate on this statement? I have found customer service to be great at TST. Cannot imagine why you feel it is the "biggest mistake" you have ever made. And you live very close to the source of supply. Did you go over there screaming and holloring and they threw you out of the office? If it was installation problems, maybe you lack the knowledge of self installing the unit. Like I said in a previous post, mine has worked well for 6 yrs. I have had sensors batteries go dead, and even had one sensor leak, but I replaced the problem ones and moved on. Feel much safer on the road with my system working than without it. - JaBobExplorerBuying one was my biggest mistake ever.
- fj12ryderExplorer IIIMy TST agrees with my gauges. If it's 80° when the MH is sitting then the TST will show 80°, depending on whether it's in the sun or not. Your question about increase in tire pressure and temp is too ambiguous to be answered cogently.
- RichertExplorerJust ordered a TST 507 system, just wondering what I should expect to see on differences in Tire pressure and temperature. I inflate to 105 lbs with my gauge, will I see the same with the 507 system. Also, if it is 80 degrees when the MH is sitting what is the general increase in tire pressure and temp, just wondering doesn't have to be specific, looking for what to expect.
- peaches_creamExplorerI am using a TST system that is 6 yrs. old. I have had the batteries changed in sensors replaced a few times. New systems have owner replacable batteries. If I ever change mine, it will be to that. At 1 time I was monitoring 12 tires (8 on MH and 4 toad). I also purchased the repeater to increase signal from toad to receiver. I hang it on the rear view mirror of the toad and plug it into acc. plug. I would also suggest getting one that allows inflating tires without removing sensors.
- MikepyExplorerI have a TST system with 10 sensors. There is a tow disconnect that deactivates the monitoring for the dolly and vehicle, if your not towing them, so you only see the sensors your using. I don't know if other systems have this.
- lryrob9301ExplorerI have the Tire Traker system with 10 sensors and it works very well.
- 2oldmanExplorer II
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
