โDec-31-2013 09:42 PM
.......and I just may have.......
I'm on "CB-13", are you?
โJan-01-2014 11:11 PM
โJan-01-2014 08:57 PM
โJan-01-2014 06:03 PM
โJan-01-2014 06:02 PM
โJan-01-2014 05:42 PM
deltamaster wrote:
I also understand that the digital signal is more directional than the old analog and that if the antenna is not pointed precisely the TV will not find the available channels.
โJan-01-2014 04:42 PM
wa8yxm wrote:
THe Winegard Sensar Pro then is what you want, 100 bucks (Rounded) one time, it goes between the box of many buttons and the antenna, it eats 12 volt..
โJan-01-2014 04:32 PM
deltamaster wrote:Something that's often overlooked when people talk about amplifiers doing all the heavy lifting, is that you cannot amplify what's not already coming down the coax in the first place. That's what antenna gain does, and you cannot recreate it artificially. The FIRST addition I would do is add a Wingman. THEN to assist you in pointing it, and to help offset the coax and splitter losses in the RV, add the SensarPro.
Well, I checked out the Sensar Pro at the Wineguard web site. There are manuals in PDF so I looked them over and as someone mentioned the Sensar Pro goes inline with the antenna before the switch box. I suppose that BOTH the switchbox booster and the Sensar Pro can be turned on at the same time. It is ten dollars less through the Winegard site over Camping world.
I understand about the wingman attachment but as I understand it the attachment should not be necessary.
Thank you all for your assistance. Maybe I will look around and see if I can find the Sensar Pro elsewhere for even less money!
โJan-01-2014 03:07 PM
โJan-01-2014 03:00 PM
โJan-01-2014 11:48 AM
โJan-01-2014 11:03 AM
โJan-01-2014 10:38 AM
โJan-01-2014 09:39 AM
โJan-01-2014 09:28 AM
