usersmanual's avatar
usersmanual
X2 wineguard 6000 series question
I have the sat antenna and set up with two receivers on west arch
both 211Z systems and one with a cheap hard drive to record
system for most part works very well
lately I have been losing signal on secondary receiver
as if I had switched sats which it will do(lose signal)
that is if the primary receiver switches sats the secondary will either have to be reset or not used till u return to main sat
but iam not switching sats and its acting as if I did
simply pull card and it resets(reboots) but its a pain and cant be trusted when you have a recoding set on secondary receiver
anyone with any idea as to whats up?
1 Reply
  • Set use the first set as the recording unit. Glad I could help!
    The recording unit actually should be the primary receiver and the other should be secondary. This will likely solve your problem since that's the only receiver that is going to try to automatically change channels and the other can just follow along. Just swap receiver locations or swap the cables on the X2 to ensure that the recording receiver is connected to the main output on the X2.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
