motor mount replacement
newmar40jw
I have an 04' Newmar Kountry Star motorhome c7 Cat,how hard is it to change engine mounts?
2 REPLIES 2
Grit_dog
Navigator
Navigator
If you have to ask, then it's probably a job for a bus shop.
I'd look to see where I could get a porta power type ram or jaws in by the mounts to lift or rotate the engine just enough to RnR the mounts.
Never put engine mounts in a bus before.
Tyler0215
Do you have a way to lift and support the engine while you do the replacement?
