Suburban h2o heater anode rod head size.
danly
What is the socket size to remove rod for draining. I have a 6 gal. tank. Thanks
Dan and Twi
2018 Coachmen Catalina Legacy 323BHDSCK
2003 SILVERADO HD 2500
"http://www.wunderground.com/US/MN/Minneapolis.html">
6 REPLIES 6
SidecarFlip
Old-Biscuit wrote:
SidecarFlip wrote:
Just too my old used up one out and stuck my pressure washer in the hole and blew out all the crud.
I prefer a 'power flush'
Remove drain plug/rod, turn on water supply and stand back.
Nothing sticking in thru drain hole so water pressure BLOWS crud out W/O any obstructions .......cold inlet dip tube points downward and really stirs up the sediment on bottom of tank.
Especially Atwood which has a 1/2" drain hole (Suburban 3/4")
Stick a wand in Atwood and most of drain hole is blocked :S
Not really. The business end of the pressure washer won't fit through the hole anyway. I installed a narrow spray nozzle and held it off the opening about an inch and let it rip. Blew all the stuff right out, on me and my sweatshirt and the driveway and I had a 'look see' afterwards with my bore scope and it's clean as a whistle inside.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
mbopp
27mm works too.
2019 F250 XLT Supercab
Just DW & me......
Chris_Bryant
As already said, 1 1/16". Many 4 way lug wrenches have that size.
-- Chris Bryant
Old-Biscuit
SidecarFlip
Old-Biscuit
1 1/16" -----6 point socket works best
