GlennLever's avatar
GlennLever
2 to 1 tail light conversion module
I currently have a MME 5 amp Powered tail light conversion module.
It worked fine until I put LED tail lights on the trailer.
Now the left and right turn signals work, the marker lights work, but the emergency flashers do not.
I currently have the conversion box attached to a terminal box that contains all the connections for the trailer plug on the Motor Home.
I need a GOOD quality conversion module that works with LED (low current draw)
I would like the same style, vehicle wires on one side and trailer wires on the other, well labeled and flat
  • GlennLever wrote:
    ChooChooMan74 wrote:
    Unfortunately, they must have changed it since I got mine (Notice in the description, it says "upgraded") Mine looks like this
    That is more what I am looking for. Manufacturer? Does it state it is good for LED lights?
    That is the old version of the link that I provided above. They changed the design. The old number is tow ready 119190 and the new one is 119191
  • Unfortunately, they must have changed it since I got mine (Notice in the description, it says "upgraded") Mine looks like this
    I use this from eTrailer. I used it in 2 vehicles that had amber turns. I installed this after installing LEDs in my first vehicle, that totally messed up everything with another converter in place (probably what you're going through). Then, when I got my 2nd vehicle, I put LEDs in it right away, and got this coverter again for the trailer. You can see my review on it, too, on etrailer.com (Matt M).
    http://www.etrailer.com/Wiring/Tow-Ready/119190KIT.html
    Wow, $74.00.
    I just need the module and would like the wires for the trailer and Motor Home split.
    Not in this configuration.
  • I use this from eTrailer. I used it in 2 vehicles that had amber turns. I installed this after installing LEDs in my first vehicle, that totally messed up everything with another converter in place (probably what you're going through). Then, when I got my 2nd vehicle, I put LEDs in it right away, and got this coverter again for the trailer. You can see my review on it, too, on etrailer.com (Matt M).
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,114 PostsLatest Activity: Feb 24, 2025
