TundraTower's avatar
TundraTower
A different weight question
I do not have a good understanding on how GVWR is applied to a travel trailer rig. The question is whether the tongue weight and it's effects have to be counted in both the truck and trailer weights.
1. If we weigh the coupled rig on the scales the sum of the truck axles would compare to the truck GVWR, but the trailer axles are only going to represent the trailer wheel weight and not include the tongue weight. But it does represent how the rig is actually loaded.
2. If we weigh the truck and trailer separately, that would fairly represent those weights separately but does not reflect how the truck is loaded going down the road.
3. If we compare connected truck weight to its GVWR, and then compare the uncoupled free standing weight of the trailer to the trailer GVWR, then most of the tongue weight is counted twice - once on the truck and again on the trailer.
It is this #3 concept that I have been using but I struggle with having to count tongue weight against both ratings.
I'm not asking if it's legal, whether you would get ticketed, how the axles or tires are rated, whether I need SRW or DRW, etc. And yes I know about and understand the GCWR which is straight forward.
Just simply trying to understand how the tongue weight should be applied relative to the GVWR of the truck and trailer and whether it is actually intended to be counted twice.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
