Jul-21-2021 07:08 PM
Aug-03-2021 09:29 AM
Frozen001 wrote:
Well, I returned home over the weekend, and with the replacement standard bracket and noticed that the new one is beginning to bend. So I decided to get my tongue weight.
Yesterday via the bathroom scale method. In my first measurement, I got 1350lbs of tongue weight. This is with the trailer not fully loaded for a trip. Missing are basically clothing and food items as that is pretty much what we have to pack for a trip. I also will sometimes travel with some water in the fresh tank, so I added about 1/3 of a tank and the tongue weight went up to 1500lbs. Either way, I am looking at DOUBLE the published tongue weight. I understand that the published is basically empty with no propane tanks, battery, etc, but I did not expect it to be double when loaded.
So I am grossly exceeding both my bars, and the standard snap-up brackets (which BTW are rated at 800lbs it appears). Guess I going to move up to the 16K Equalizer setup, as buying the pieces to the Reese are also the same cost. This will get me some increased ground clearance (at least it appears I will).
Aug-03-2021 07:44 AM
Jul-27-2021 03:40 PM
Jul-26-2021 12:48 PM
Jul-26-2021 08:59 AM
Jul-25-2021 08:42 PM
Frozen001 wrote:
As a side note… I posted about a month ago about the drivers side seeming to have more tension that the passenger side. Not sure if those event and that are related… but makes me wonder.
Jul-23-2021 03:37 PM
Jul-22-2021 07:10 PM
Jul-22-2021 11:52 AM
BarneyS wrote:
That exact thing has happened before and posted here on the forums. I have not taken the time to look it up but the take-away from the discussion is that Yes, the V formed by the intersection of the driveway and road PLUS the turn you were making put too much pressure on the snap up.
You have a couple of choices to prevent it in the future. I would probably do both if the tongue weight is over 1000lbs.
1. Purchase the heavy duty brackets that have the reinforced top part.
2. Thru bolt those brackets to the frame. Reese has approved this for heavy tongue weight trailers.
I would not worry about the dent in the frame.
Barney
Jul-22-2021 10:03 AM
Jul-22-2021 06:23 AM
