galtgirl's avatar
galtgirl
Best Stackables for an RV
What are the best brand of stackable washer/dryers for a new RV.
I've seen the Splendide but notice lots of posts mention Whirlpool. Are the Whirlpool also front loaders? How do they compare in both price and efficiency?
  • The Whirlpools are front load, been using ours since '06.
    Regards
    Gemstone
  • We have the stackable Splendides and they work very well. The dryer is 110v and takes longer to dry than a residential dryer. We can wash everything in the washer except our quilt. You may be able to find the small Whirlpools at a big box store for less than the Splendides. Ours were factory installed with a catch pan underneath with a drain through the bottom of the RV In case there is some sort of issue like a hose rupturing. We also have an access door so we can get to the back of the units without having to pull them out. No more nasty laundries for us!
  • There was a thread a couple of years ago where some had used a stackable propane washer and dryer system from Sears. They said it used very little propane, dried quickly and was vented outside.
