silvercorvette's avatar
Jun 18, 2013
Do washers made for an RV differ from home models.
Here is the reason why I ask. All the models made for home use have braces to protect it from damage due to bumps during shipping. That seems to indicate to me that units that aren't made for boat & RV use are more likely to be damaged from bouncing around.
Are washers like the Splendide better suited for RVs?
  • stickdog wrote:
    If you get an unbalanced load you'll find out how much vibration a Splendidi can take.
    I have used the Splendide over a dozen time in the short while I had it. When ever the load is unbalanced the washer slows down and self adjusts balances the load.
  • If you get an unbalanced load you'll find out how much vibration a Splendidi can take.
  • Our Whirlpool apartment sized stackables had the same shipping braces as the fullsized units...been "bouncing" down the highways for seven years in three different RV's...not one issue. Don't think special dampening is required.
  • silvercorvette wrote:
    WyoTraveler wrote:
    We have stacked slpendide units. They are bolted down so they don't move around. Wife likes the stacked units better than the combo unit we had a few years ago. Just 2 of us so just small loads are ok. Wife can throw a load in and we can be off doing things we want to do instead of sitting in laundry room 1 day a week.
    I have a splendide combo, that was just installed last month when I picked up my H/R Alumascape. I didn't have a chance to see how it came packed from the factory and if there was extra packing for transportation purposes. My theory is that a unit designed for use in an RV may have special dampeners in it to absorb bumps when you travel but a compact unit made for home unit would not requite anything special because it would not be expected to be tossed around. I assumed that when I bought the Splendide it would be designed to handle bumps better and be more durable
    The pan on the new one is white plastic. Old one it was just unpainted metal. It has a drain to the outside. I never had any leaks in the hoses just a small leak in a relay in the washer when in use. Not a whole lot of water. Just enough to make a mess with no pan. It looked like it had been leaking for some time before wife noticed it. We just got the new one installed. First class job by Monaco in Coburg, Oregon.
    Splendide has also been a good company and good customer relations. BTW did you get the drain pan installed under it? We did have a leaky relay in our combo unit when it was new. The pan saved the floor. Had a pan installed under my new unit also. Well worth thee money.
    I bought the 2009 Alumascape from Happy Days in FL andI purchased the washer new. Happy Days had it installed by the time I arrived, if there is a pan I don't see it. I have done 10 or 12 loads of clothes since I got it and I am always in bed near the washer when I am using it. I think I would notice a leak if there was one but I will investigate buying a pan when I get home. I always turn off the water supply when the washer is not being used so there is little chance it will leak when it is turned off
  • We had a Sears stackable set in our Mobile Suites and never a problem. Large capacity washer although dryer was slower than at home since it is only 110AC. We are in no hurry so no problem with washer.
  • We have stacked slpendide units. They are bolted down so they don't move around. Wife likes the stacked units better than the combo unit we had a few years ago. Just 2 of us so just small loads are ok. Wife can throw a load in and we can be off doing things we want to do instead of sitting in laundry room 1 day a week.
  • Generally they are considerable smaller, so smaller loads are the norm. Some are combo washer/dryer units. They seem to wash equally effectively. My wife is not happy with the permanent press cycles. She is ironing more often. perhaps it's because there was too much done in one load.
    It may just require retraining in these machines.
    We have not seen any problems with the rigors of bouncing during travel. Our 2006 coach (new to us in March) has the original Splendide Washer/dryer combo unit, and it is going strong. 45000 miles on coach.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
