garyhopp1
Dec 12, 2015Explorer
Flat Tow a Ford Focus
I have a 2014 Focus I am going to tow, the owners manual says to disconnect the negative terminal from the battery. Has anyone found the same issue as I have? In order to disconnect the neg terminal you would have to nearly disassemble the car in order to get to it. I ask roadmaster and they feel that disconnecting the postive term will give you the same results. I tend to agree once the battery is disconnected it is disconnected. what puzzles me is after a call to Ford Techs they appear to feel that the neg must be the one disconnected???? Go Figure??
Has anyone been towing a focus mine is a 2014 and using only the positive terminal as a disconnect or has anyone heard differently
My thought is maybe it is a safty issue of hydrogen gas and making an ark when disconnecting and Ford is just covering themselves?
