rvhippo's avatar
rvhippo
How do I not blow up my city water connection check valve?
Jayco plumbed my city water connection line so that I will have trapped water against the valve after winterizing with antifreeze. Everything else looks like it should gravity drain.
Can I just press in the check valve and let the water drain out?
I have read here that I can blow up the valve if I do this.
Why would the valve be damaged by doing this?
Thanks in advance for any replies.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 25, 2025
