- larry_cadExplorer II
Cummins12V98 wrote:
fj12ryder wrote:
C'mon, these 50 amp cords aren't that bad. Unless you have disability problems it's just not that big of a deal. I'm 74 and getting it out of the truck, coiling and uncoiling, and plugging isn't enough to really stress anyone out. Sounds like you guys need to eat a bigger bowl of Wheaties. :)
The meaning of a "Manyl Man" right there folks!!!
:B - rhagfoExplorer III
Cummins12V98 wrote:
theoldwizard1 wrote:
rhagfo wrote:
Well we built our own with correct ends for 50 amp cable. The cable is 6/4 SOOW electrical cable. It is rubber insulated rather than PVC. Stays flexible even below freezing.
6/4 SOOW cable
There is no need to use SOOW cordage ! It is rated for 600V. SJOOW is rated for 300V. Also rubber insulated.
Depending on the length, you probably only needed 8/4.
My cord is from a temp power box. It's 6/3 & 8/1 for the ground. Mine is "SOW"
While that is true, I got my cable from a fellow forum member for a very good price. That said, I would not step down to a 8 gauge cable as with Cheap heat I draw 20 amps on both legs during winter.
The real killer is that I wasn't sure my 40' cable was going to reach the 30 amp outlet I installed in my daughters garage when we spent last July there. I built a 23' SOOW extension cord, but I easily reached with our 40' cord. - fj12ryderExplorer IIIVery close, but it was a Big Chief tablet, we didn't have loose leaf notebooks at that time. :) And a #2 pencil.
- way2rollNavigator II
Yep, walked to school in 6 feet of snow, barefoot, uphill both ways after killing a bear with a loose leaf notebook. - Cummins12V98Explorer III
6/4 SOOW cable
My cord is from a temp power box. It's 6/3 & 8/1 for the ground. Mine is "SOW" - Cummins12V98Explorer III
The meaning of a "Manyl Man" right there folks!!! - way2rollNavigator IICord reel might be helpful. Had one in our previous FW and it was a nice feature. Ours was powered but I am sure hand crank ones are pretty cheap.
- Darryl_RitaExplorer
6/4 SOOW cable
Thus the comments on the weight difference. SOOW is going to be heavier than SOW, and 6/4c heavier than 6/3c 1/8, and even a bigger difference than 8/4c. - theoldwizard1Explorer II
6/4 SOOW cable
Depending on the length, you probably only needed 8/4. - fj12ryderExplorer IIIC'mon, these 50 amp cords aren't that bad. Unless you have disability problems it's just not that big of a deal. I'm 74 and getting it out of the truck, coiling and uncoiling, and plugging isn't enough to really stress anyone out. Sounds like you guys need to eat a bigger bowl of Wheaties. :)
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,108 PostsLatest Activity: Feb 01, 2025
