lawnspecialties's avatar
Sep 27, 2022
Load Range F Tires
My heavier landscape trailer has the typical Load Range E 235-80-16 tires. I've probably bought a dozen sets in my landscape career. But they live a hard life for the most part. This trailer sometimes sits for a month or more underneath a shelter but when I need it, it works hard. Today as I prepared to head out with my tractor, I noticed one tire was out of shape. I checked all my air pressures and they were pretty good. I brought them all up to 80 psi. But I was thinking that one lame tire had busted a belt or something. Once I got going, it was clear it probably wouldn't make it through the day. It was so out of balance, it would vibrate the truck. Sure enough, after about 35 miles of hauling, it went flat. My spare was pretty good so I was able to continue on for the day.
So now I'm on eBay and I'm wondering if I should go to F rated tires. I think G rated tires are way overboard for this application. 10,000 lbs, including the trailer, is the rare maximum these tires will ever have to carry. Not to mention the price of Gs are far more expensive. But I have two questions.
1. F rated tires have a max. pressure of 95 psi. I know G rated tires have such a stiff sidewall, that if you let the air pressure get really low, it could damage the sidewall. Are F rated tires the same?
2. Is this even a good idea or a waste? They're only $10 more per tire. But I just don't want to have a tire that may not be more durable in this application plus I can't run a tire that's prone to sidewall damage just because it sat underneath my barn for a couple of months and maybe a minuscule leak caused it to drop 50 lbs. over that time.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 23, 2026
