OFDPOS's avatar
OFDPOS
Need To Check Those Marker Lite Covers
While I was replacing the amber marker lights up top on the front with new LED's , 4 out of the 5 old lens covers were cracked !
Actually looked like hit from rocks ! The window up front the housing is somewhat blasted too (black paint chipped up good)
But anyway from the ground looking up I couldn't tell , they all looked fine, but once up on the roof and removing the old lens covers 2 actually were cracked bad enough that water had gotten in and with the dust build up the dirt was crusted ..
I checked and could tighten 4 out of the 10 screws holding the backing plates . Careful tho they can strip real easy !
I cleaned them up good inside and out then put a bead silicone around the them, the old chalking was cracked on most of them.
Just a heads up to really check things out good !
Happy Camping
    Actually looked like hit from rocks !.....
    Actually it's from all those times we go under low branches at a CG and it sounds like just soft leaves hitting the top of the RV. Well the leaves are attached to branches and those lens take a beating over time!
  • Yup, I've learned to inspect mine each spring during the roof inspection.
    I also turn the lights on and walk around carefully looking at each light for something amiss a couple of times a year.
    I have found times when there was a light out and it was just a bad connection. They are build so cheaply.
    Converting to LED's would be a good investment.
  • I am going to replace the whole unit. I get where you are coming from, older units will have all kinds of gunk in and around the lens caps.
    We just bought a Horizon and I plan on replacing all the units, lower power consumption and easier on the alternator.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
