ewarnerusa's avatar
Jun 19, 2017
Replacing coroplast on entire camper underbelly
I lost the entire coroplast liner that enclosed my camper's underbelly this weekend. I think the root cause was from some axle work I had done two years previous. I noticed then that they didn't fully reattach the coroplast to the frame very well at the axles. I had always meant to button it up better but never got around to it.... I figured water spray could get up in there and weigh it down and eventually have it tear. Turns out that air alone must have done the job.
While driving to the destination this weekend I was passed by a car that rolled their window down and gave me the signal that something was up. I pulled over and found about the third of the coroplast liner still attached to the very rear of the camper and dragging on the ground. The entirety of the rest of it was completely gone! Luckily it didn't tear any wiring out or propane lines. It did tear the handle off of my gray water dump valve. I had to screw a long wood screw in as a hack to get the tank dumped.
So has anyone else replaced the entire liner before? Dealer or DIY project? Cost? Thanks.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
