Brancor
Feb 06, 2016Explorer
Suburban SW6P Water Heater
Question here, Newbie to travel trailer here. First time water heater owner in a camper. Dealer has not responded to calls or emails. I have a 2016 Keystone Springdale Summerland Mini 1800BH. I just have a question on what I need to do to make sure my WH works correctly. I removed the bottom bunk mattress and board to see the holding tank, pump and back side of the water heater. I only see one (1) valve behind the water heater. The camper is winterized currently by the dealer. Not sure how upload a pic to show what I am asking. I can email it if need too. Between the red pipe and blue pipes for the hot and cold, there is a blue pipe that connections those to those pipes, the valve is at the bottom of that on the cold water connections. That valve is running with the connector pipe. When it is time to start to use this WH, do I need to turn that? If so, only after I have un-winterized the camper?
Updated pic link??
***Link Removed***
***Link Removed***
Thanks
Newbie....
Updated pic link??
***Link Removed***
***Link Removed***
Thanks
Newbie....
