Almot's avatar
Almot
Jan 11, 2015
Travel trailer brakes - magnet question
No photos, sorry. Brakes are similar to those in Sticky thread here. 3 major parts - 2 shoes and magnet on some "arm", for lack of better word. Being not a mechanic, I hope my descriptions make sense.
Short story: I think magnet on one wheel is causing drug, rubbing against the wheel drum when brakes are NOT in use. I can rotate the wheel with my hands, but it won't spin, goes maybe one inch and stops after I let my hands off. I can hear constant friction noise like "shhh" when rotating. Magnet is sitting on the spindle of the arm, and there is a spring on this arm behind the magnet, and I think something is missing.
Q1: how far and how fast can I go with this? I'm in Mexico, closest good mechanic is 15 miles away, and charging US prices, for God's sake. Would like to go as is, 300 miles to where I want to be, if possible.
More details and Question 2:
I opened this one brake because it wouldn't spin after the hurricane with mud up to the axle. It turned out to be just mud inside. Bearings were fine, I repacked the front bearing since I opened it anyway. Could've lost some retaining ring from that "arm" that magnet is sitting on - while opening the drum, or some time earlier. So the magnet is now pushed by the spring from behind all the way to the inside surface of the drum. This is I think what happened. Sand is like water, you drop something and it's gone.
Q2: what this washer or ring might be?
Other 3 wheels I can spin, at first they didn't, I slowly rotated them back and forth, mud and other cr.ap came out and they spin now. Won't open them now, just will have mechanic to blast them with air and brake cleaning fluid. I can hear intermittent metal sounds like brake shoes or some garbage is touching the drum, but they spin.
