dvitale300 wrote:
2015 Starcraft Ultralight. I know - it’s weird but replicatable. Got out of the shower - fine. Turned the trickle off - heater went off. Turned city water on - doesn’t work.
Then you do not have a thermocouple.......just the spark electrode which provides the high voltage spark for ignition AND the return path for the 'flame proof' signal.
When main flame lights off a milliamp signal is generated via flame rectification
This signal proves main flame has lit and circuit board can hold DC on gas valve.
W/O that signal getting back the circuit board drops DC off of the gas valve solenoids shutting down propane flow so raw fuel doesn't accumulate
3 attempts then circuit board 'faults' and 'locks out'
Clean up, reposition, replace spark electrode
Clean up and tighten ground connections of water heater
Green wires and the spark electrode assembly mount screw
Thermal Fuse (clear tube---brown wire to t-stat), t-stat and ECO (Energy Cut Off---Hi temp T-stat) are not the issues
If Thermal Fuse was bad............NO DC/No heat functions period
If t-stat..no heating OR if loose then temps would go HIGH
If ECO....no heating OR if loose then temps would go REAL high and T&P Relief Valve would be dripping/ready to pop open
Spark Electrode........
