CHD_Dad's avatar
CHD_Dad
TV tire pressure (mainly the front tires)
Looking for some clarification on TV tire pressure, I am clearer on TT pressures. I was always under the impression that you were supposed to air up your TV's tires (ALL FOUR) pressure to max cold when towing (especially with P rated tires). It's just what I have been told since starting to tow as a blanket statement.
Then I found out about load charts and you should match tire pressure to load placed on tire. That is all fine and good. Then I was looking at my scale weights and thinking about how several new MFG guidelines now specify you only need half the weight restored to the front of the vehicle.
Brings me to this - are your FRONT tires supposed to be aired to max, according to a load chart, or according to the MFG daily driving pressure (non-towing). Reason I am asking is that at best with 100% restoration of weight you are back to the factory weight of the vehicle, you should never be placing More load on the front no matter what you drive. With some vehicles you can now get away with half the weight being redistributed back up front. With either scenario if you do air up the front tires to max you are decreasing the tire footprint on pavement. In the case of reduced weight up front that footprint is even smaller.
So, what should you set the front tires to pressure wise and why do you recommend that pressure? Is it strictly for squirm resistance? Another reason? After thinking it through I think I have been doing it wrong all these years and need to get that pressure back down...
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
