acritzer's avatar
acritzer
Jun 11, 2017
Water pump cycles on and off?
Just replaced my water pump. It's a shurflo 4008 I think. It cycles on and off when I turn on a faucet, water flow is fine, but the pump constantly turns on and off...about 1 sec between each.
This did not happen with the old pump so I'm assuming the plumbing is all ok. Do I need to adjust the pressure setting screw? I've read that if I back it out a bit (counter clockwise) I can fix the cycling.
Is this an Allen wrench screw?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,135 PostsLatest Activity: May 24, 2025
