bsmith95610's avatar
bsmith95610
Which weight distribution setup do you recommend?
Hello,
I just purchased a travel trailer and am now looking to get a weight distribution hitch. My trailer is 23 ft long and weighs about 5000 lbs loaded. I don't want to buy a cheap weight distribution hitch but I definitely don't have the funds to get an expensive one either. I am hoping to get something that comes with sway control but if not then I'll add it later on. Below are the hitches I've been looking at in order of what I'm thinking about buying with the most likely on top so please let me know if you have any feedback on any of them. I picked out three on the cheaper side and three in the mid-range side. Any help would be much appreciated.
Pro Series Weight Distribution System w/ Friction Sway Control - Round - 10,000 lbs GTW, 750 lbs TW - $256
https://www.etrailer.com/Weight-Distribution/Pro-Series/PS49902.html
Curt Weight Distribution System with Shank - Pin-Style Trunnion Bar - 8000 lbs GTW, 800 lbs TW - $255
http://www.etrailer.com/Weight-Distribution/Curt/C17341.html
Eaz-Lift 48057 Elite Weight Distributing Hitch Kit - 800 lbs Capacity - $241
http://www.amazon.com/Eaz-Lift-48058-Elite-Weight-Distributing/dp/B005SB6S3Y/ref=sr_1_1?s=automotive&ie=UTF8&qid=1464973279&sr=1-1&keywords=Weight+Distributing+Hitch
Curt TruTrack Weight Distribution System w/ Sway Control - Trunnion - 10,000 lbs GTW, 1,000 lbs TW - $379
https://www.etrailer.com/Weight-Distribution/Curt/C17500.html
Husky Center Line Weight Distribution w/ Sway Control - Trunnion - 12,000 lbs GTW, 1,200 lbs TW - $400
http://www.etrailer.com/Weight-Distribution/Husky/HT32218.html?feed=npn&gclid=Cj0KEQjw1cS6BRDvhtKL89em1oIBEiQAtZO5x9g5xZMpJWPI9FkZ7_HeacRZgClGVGH9pGrt4x0vBZUaAm5y8P8HAQ
Strait-Line Weight Distribution with Sway Control - Trunnion Bar - 10,000 lbs GTW, 800 lbs TW - $480
http://www.etrailer.com/Weight-Distribution/Reese/RP66073.html?feed=npn&gclid=Cj0KEQjw1cS6BRDvhtKL89em1oIBEiQAtZO5xwocJbkZNm-nuz_73emfNEbEBwtYDuTlBTh9XCKDHxkaAjWz8P8HAQ
Thanks
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 17, 2025
