dcmac214's avatar
dcmac214
? Will Lime-A-Way Damage Toilet or Seals?
Will using Lime-A-Way cause any damage to toilet and tank seals? I assume it's safe for the plastic toilet itself, have yet to see it do any damage to anything plastic. But I don't know about the RV's (rubber?) gaskets/seals.
Problem: Years of uber-hard water has left an invisible and undesirable coating of mineral on/around the toilet bowl (SeaLand). Scrubbing with brush and rag with dish soap won't take it all off. Don't want to use greenie pad or scouring powder because that will scratch.
  • I use SOS pad to clean water stains in shower. It doesn't scratch. That Lime away is very caustic stuff.
  • Squirt a generous amount of liquid automatic dishwashing liquid in your toilet and let it sit. After an hour, use a toilet brush and scrub it and flush it. If it breaks down lime and water spots on your favorite wine glasses, imagine what it will do for your bathroom? (FYI, works great on glass shower walls and doors too).
  • use vinegar instead...let it sit in the bowl for an hour or so, then scrub and flush.
  • From product sheet:
    Warnings
    Keep out of reach of children. Danger: corrosive to eyes and skin. Harmful if swallowed. Read precautions on back. Note: do not use on natural marble, stone, terrazzo, polished or anodized aluminum, metallic or painted surfaces, colored grout or counter tops. May etch some older or worn porcelain tubs and sinks or ceramic tile. If in doubt, test hidden areas first. Avoid contact with wood, fabric and wallpaper. Wipe up spills immediately and rinse with water. Not for use on food contact surfaces. Do not use on cookware, coffee makers, tea kettles, humidifiers and washing machines. Danger: corrosive. Harmful if swallowed. Causes eye and skin damage. Do not get in eyes, on skin or on clothing. Do not ingest. Do not breathe vapor or mist. Do not mix with bleach or other household chemicals as harmful fumes may result. Handle with care, wear rubber gloves and eye protection. Use in well-ventilated areas. Contains sulfamic acid. First aid: if in eyes, immediately rinse eyes thoroughly with water. Remove any contact lenses and continue rinsing eyes for at least 15 minutes. Get immediate medical attention. If on skin, immediately wash with soap and water. Get immediate medical attention. If swallowed, rinse mouth and drink a glass of water. Call a physician or Poison Control Center. If inhaled, move person to fresh air.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
