cpaulsen
Mar 27, 2020Explorer
110 outlets
2018 Montana...…..mo 110 outlets in front half of 5th wheel . Thought it was circuit breaker...….not! Then GFI in bathroom.....not again!! Anybody have any ideas. I ihave to power going to the circui...
cpaulsen wrote:
Thought a GFI to start with. Onle one we have is in the bathroom...all other outlets are kinda like daisy-changed to the one and only GFI. And no power at the first2 double beakers in the panel. Have checked all connections so far. All worked in the morning before we left one rv park and got to another one and then the problem appeared. Guess I should pull every outlet and check the wires since the GFI will not reset.
The GFI needs to have power to it, in order to be able to be reset it.
