Dave_H_M
Nov 03, 2013Explorer II
12V Power From TV Prob?
This problem just cropped up on the most recent short trip.
For years when we stopped for an overnight dry camp, like wally world, I let the truck power cord hooked up and the truck running until it was bed time and shut things down so we started the night with a full batt if we needed some heat at night.
I usually go by the idiot xmas tree light on the fifth wheel panel. So last time out I pushed the switch to check and only three lights at max with the truck plugged in and engine on high idle (900rpm). Everything was great until the last trip.
I tokkk the batt to town and had it put on the tester. Techie said it was good.
So I probe around underneath front panel and look for the lead coming in that comes from the connector on the truck. I found a black wire that showed 14.2 volts when disconnected from the system. This corresponds to 14.2 volts showing up on the TV batt.
So if I take this wire that shows 14.2 V and apply it back to the system the voltage immediately reverts to battery voltage. it seems like voltage is there but no load can be provided.
What could this indicate? I thought maybe a poor connection either in the box on the RV or somewhere in the truck harness?
I got the voltage but no power (amperage), however it all worked great since 2010. Any thoughts?
