- Many VIN numbers including mine shows a 7 as the seventh character. It is a basic P-30 chassis. No one has been able to clarify why VIN shows it as P-37 motorhome chassis as compared to a 0 as seventh character indicating a stripped bare chassis.
- petesautoExplorerI believe my rig is on a chevy P37 chassis
- petesautoExplorerfuse links by starter are ok...will check out light switch
Pete - The Wiring TO the Headlamps and lights is Chevy. The Dash switch is Chevy and has a built in Circuit breaker. Start at the Dash switch. Odds are you will see burnt connections on the switch. Doug
- Did you try the answers in your other post?
Did you check the fuse links by the starter?
Chilton's General Motors Full-size van manual, 28642, has basic wiring diagrams. It does not show much for lighting wiring diagrams.
Your chassis is a GM (Chevrolet) P-30.
