lbond01
Jan 12, 2018Explorer
2003 Cummins engine whine @2000+ RPM's ( Solved/Muffler?)
I have a 2004 Bounder Diesel on a 2003 freightliner XC with a Cummins 5.9 ISB. I had a over heating problem. I found the cooling fan had chunks missing on some of the blades. Had to remove radiator/charge cooler to get to it. Radiator was rebuilt and cleaned out (was plugged up). They tested the charge cooler and they said it looked like a sauna in the test tank. Replaced Charge cooler and both cold side boots. Got everything back together and now I have a high pitched whine that starts at 2,200RPM's and up and is pretty load (see video). Someone suggested that muffler was plugged up. Disconnect muffler and sound is there still. I have used a mechanics stethoscope to listen to turbo and alternator. They both sound normal. The sound kinda sounds like it is coming from rear bottom of the engine near fan. Maybe belt tensioner roller? Anyone ever heard this sound?
Fan blades
5.9 ISB whine
Fan blades
5.9 ISB whine
