Aesop1's avatar
Aesop1
2005 Safari Simba Hot Water heater 120 volt Electric
https://imgur.com/a/lx6WYkcHello,
Recently got a new-to-me 2005 Safari Simba Motorhome 30 ft with the vortec 8100.
The hot water heater works fine on propane, however on the electric hot water heater switch on the panel right next to it, where the switch is in the "off" position there is a faint red light. However when the electric hot water heater switch is then flipped up into "the on" Position the light then goes away completely and the hot water heater on electric doesn't appear to work at all.
I've checked the fuses in the bedroom of the motorhome and they both seem to be fine.
here are some images of the control panel
Does anyone know why the hot water heater on electric is not working? The motorhome is hooked up to shore power.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
