deanathpc
Jun 16, 2005Explorer
bobgay wrote:
Unpacked the ELM3000 I bought over E-Bay and fired it up this morning. Engine runs fine, but I am not getting any electricity. I've tried it with each circuit breaker switch in the on position and with both on, but the voltage meter shows zero (on 110 or 240), and it will not even run a small fan I plugged in.
With the selector switch in the 220 position the needle twitches a little, but on 110 it is flat dead. Am I forgetting something? The 110 volt outlet, by the way, is polarized. I hope I haven't bought a $360 boat anchor. I'd appreciate any ideas.
Bob
Got a knock from E-bay some time back... Make sure all the wires are connected to everything.. When I got mine some were loose... May not be the solution for you but it's a start... would be a bummer if it was a boat anchor....
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
