bobgay
Jun 16, 2005Explorer
I got it working. I think the problem all along was the green wire had come unclipped from the AC Motor Capacitor. I think the green and yellow wire was a ground wire running from the 110v receptacle to the ground. They were using as a ground one of the bolts that attaches the panel holding the receptacle. It apparently came loose when I removed the panel. I attached the green wire to the capacitor and the green and yellow wire back to the panel bolt, and it seems to be working fine. Thanks to all for the help.
Bob
Bob
