professor95
May 24, 2006Explorer
Hi, I'm a newbie here.
I bought a Wen PowerPro 3500 after reading this thread for a while (Menards - $279 - $25 rebate). I bought a Coleman wheel kit, but it is meant for square tube rods, not round. Is there a way to retrofit? Could I attach some square tubes to the round somehow and then attach the Coleman kit?
The Champion generator is similar - round tubes on the frame and the wheel kit handle requires a square tube. Champion has welded two pieces of flat metal stock to the tubes to give two flat surfaces at the attachment point. Of course, welding to a genny that has (or had) gas in the tank is not a good idea.
Perhaps some angle iron and a few sheet metal screws or nuts and bolts to hold it to the tubing will give you the needed flat surface? Home Depot and Low's carry short pieces of angle iron under the Crown Bolt product name.
