Ready_ToRoll
Jul 27, 2006Explorer
O.K., I just went out and tested the 120v outlets on my (Costco) PowerWise 3000w.
Not running, voltage switch to 120v. Meter on 200 ohm range:
ground to chassis 0.8 ohm
neutral to chassis 0.8 ohm
hot to chassis 1.0 ohm
Not running, voltage switch to OFF. Meter on 200K ohm range:
ground to chassis 0.0 ohm
neutral to chassis >200K ohm
hot to chassis >200K ohm
Running, voltage switch to 120v. Meter on 200 vac range:
ground to chassis 0 v
neutral to chassis varies 0 to 3 v
hot to chassis 122.5 v
So, it looks like the grounded neutral is a design flaw in the PowerWise generator, and not just a problem with Cloudswrest's unit.
If someone does a fix on their Powerwise, please post a description here so that I might do the same.
Also, sorry for previously posting a link to a document that may have been mis-leading. I (should) know better than to cite a single sentence without checking the actual codes.
Bruce
Edit: When I use the word "chassis" I mean the generator frame. I am not connected to the trailer.
Bruce
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
