MrWizard
Jul 29, 2006Moderator
CabanaBoy wrote:
I googled "generator grounding bonding" and found this site...it gives several pictorial examples of generators and whether or not they need their own grounding rod.
Generator Grounding
from the website
If the generator neutral is grounded then the generator can only be used with a transfer switch that transfers the neutral, or as a stand alone generator for a carnival or special even, and then ground rods are required.If the generator neutral is grounded then the generator can only be used with a transfer switch that transfers the neutral, or as a stand alone generator for a carnival or special even, and then ground rods are required.
ground rods are required for generators with bonded netural
