MrWizard
Jun 29, 2007Moderator
I can't get over how so many of you have no trouble with the Champion Generator. While I like mine and it seems quiet enough...when I run *only* my AC, the voltage drops to below 100, the AC compressor rattles like crazy and the generator shakes like mad. I have blown 2 voltage regulators as well. I wish I knew why this is happening.
have you tried opening up the A/C unit to get at the wiring, and putting an AMP pro around the one of 120 wires comming in
this could be too much load on the generator from a compressor on the way out ? amping the line and finding out the actual current the A/C is using, would give you a much better Idea of whats going on
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 25, 2025
