mitt
Jan 22, 2008Explorer
professor95 wrote:mitt wrote:
prof-
If you want an "off the shelf" method for this, check out the Magnecraft Voltage Measuring Relay 831VS-120A
Looks nice. Any idea what the cost is? There are a couple of distributors in the Richmond area, guess I could call to find out if it is stocked and how much.
BTW, the "old technology" method I mentioned is basically free if you have a good electronic scrap box (which I do) and like putting things together with a little wire and solder.
The best price I have found so far is $44, from b&b electronics (www.bb-elec.com).
Allied Electronics also carries them, for about $68. The 30A power relays are cheap, like $7.
I am looking at ways to test one before I buy one (we use similar devices at my work for testing).
I don't like the idea of just killing the generator, since it is stated in every instruction manual, do not shut off generator while loads are connected and running.
mitt
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
