LittleBill
Mar 15, 2008Explorer
tvman44 wrote:
Go to the Champion website and there you will find all the service information you can use on this ginny.
http://www.championpowerequipment.com/tb/CPETB1020001%20Valve%20Adjustment.pdf
HTH.
Wish all manufacturers were this generous with their information.
Different valve clearance in this bulletin
word to the wise, valve clearance numbers are different between the two bulletins. i have a 1st generation rocker assembly elim3000. my generator was sitting at the valve clearances listed in this document. i of course tried to adjust them breaking the stud bolt on the intake valve. hopefully i can get a replacement bolt.
notice they say to run 2 plates for durability i only have 1 plate maybe i will get another
watch the clearances and decide for yourself
