Dannyhawk101's avatar
Dannyhawk101
91' Onan 8KW Gen trips 15 amp DC Control Breaker
Greetings! I have an Oldie but Goodie :) 8 KW Onan front slide out Generator Model 8dkdfj spec 40216c on my 91' American Eagle. There are two (2) 15 amp DC Breakers on the remote Start Control Box in the RV. One (1) for DC Battery Charge and the other is a DC Control Breaker. Recently began to blow the 15 amp DC Control Breaker upon start up after an Oil and Filter change. Also had a thermostat problem (sticky) and so I removed it for the time being until I get over this breaker issue. The wiring harness was repaired on the fly last year by protecting some brittle wires near the exhaust with duct tape very carefully and have had no problems since. So I'm a bit reluctant to unravel that at this point until everything else fails. Soon after I release the start button and she starts the breaker blows and she shuts down. Verified that the breaker itself is good, checked my coolant and oil levels everything ok there, so I am at a bit of a loss here on where to look next. The manual suggests that if the the problem was caused by a faulty Temp Shut Down switch or a faulty Oil Shut Down switch it would blow the small round Fault Breaker in the box. That is not happening only the 15 Amp DC Control Breaker is blowing??? Thank You in advance!!!
  • Ok... DREW E. well here I am in April but the situation has been identified finally after a couple of months of not having a Generator and fretting over the replacement cost and Chassis retrofit for a newer Model. As it turns out after replacing everything possible that could blow a fuse in the Control Box ( namely, Temp sensor switch, Oil sensor switch, Fuel Solenoid, Fuel Pump, Control Board ouch 400.00 just for that but at least I got a spare :), I mean I went back to Cummins here in Miami at least 6 times for "the" part that I knew would solve the problem. It got to the point where the Cummins Parts Sales guy said why don't you just give up and bring it in Man!. Of course I couldn't do that because they at 100.00 bucks an hour would have certainly put me in the Poor House trying to figure this one out. As it turns out the problem was a "Crumby" 12v lead off the Fuel Solenoid back to the Fan! But I did not know where that particular lead went to at first. So by sheer Dumb Luck out of Frustration I happen to try disconnecting some leads, then starting and re-starting over and over... That particular lead has a 20 Amp in-line fuse attached (must have checked that fuse 100X),,,,I hit the start switch and to my amazement the Genny kept running!. Scratched my head, Shut her down again reconnected the lead and tried again and the fuel solenoid disengages and she shuts down! So hoping that lead meant nothing to the Genny operation...lol.. I left the lead disconnected to run the Genny and she ran perfectly while I'm underway. But first time I stopped for a longer period she began to overheat. That's how I discovered it was the lead for the electric cooling fan that sits in front of the Radiator! The electrical wiring diagram for the generator doesn't even show a Fan lead! The Fan works fine albeit when the lead is connected. So now I simply remove the lead to the Fan in order to start the Genny and then reconnect after starting so the Fan runs! Apparently the electrical draw of the Fan upon start-up was enough to trip that DC Breaker in the Control Box! I HOPE THIS SAVES SOMEONE ALOT OF TIME , ENERGY AND MONEY... AND I MEAN ALOT OF TROUBLESHOOTING ON A PROBLEM THAT EVEN STUMPED THE GENSET EXPERTS HERE IN FL. AS WELL! CAME DOWN TO INSANE FRUSTRATION WHERE I JUST STARTED PULLING WIRES OFF AND STARTING AND RE-STARTING OVER AND OVER... LOL.
  • I have had many pumps fail after a long life. Direct short. Also if your model has the twist lock plug on the side of the control box. Make sure it is making good contact.
  • Finally had a chance to get back to this problem. Process of elimination here but finally think I found the problem after diagnosis of the 12 v Fuel pump. Passes a continuity test when isolating the Control Box circuit from the pump but fails when connected back to the pump. Also appears that no fuel is being pumped. Well the assumption....only and assumption because who knows what else may be lurking in this Oldie but goodie 8KW is the pump is failing or sending a dead short back to the Control relay tripping the DC breaker which in turn disengages the Fuel Solenoid causing it to shut down after running a few seconds. Pump will be ordered here through Cummins South Miami tomorrow will update after the install.
  • Reply Thank You Drew E. going to try and order a harness today from Onan. I'm also trying to nail it down a bit and rule out the possibility of any of the two sensors (oil and temp) that would make that DC 15A Breaker blow. Wouldn't want to replace those if they don't have anything to do with the DC Breaker. Again the manual states those sensors would trip the circular small fault Breaker but doesn't say anything about the DC 15A breaker blowing. Perhaps the harness would most likely be affecting that. Basically trying to figure out what component(s) ( e.g. , voltage regulator, etc. ) that breaker specifically handles rather than start replacing things that have no effect on it. Going to see if I can dig a wiring schematic out of the manual today. Thank You!
  • Could be lots of things I suspect, and I'm far, far from an expert on generators. However, it does occur to me that a questionable wiring harness could be sporadically shorting out due to vibration when the generator runs. Especially since the harness is going to need some TLC sooner or later, I would probably bite the bullet and refurbish it properly and see if that cures the problem.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
