โAug-19-2014 05:46 PM
โAug-20-2014 01:47 PM
โAug-20-2014 12:33 PM
โAug-20-2014 12:10 PM
โAug-20-2014 12:03 PM
โAug-20-2014 10:20 AM
BFL13 wrote:Old-Biscuit wrote:
Good for you........
Item #2
Material doesn't move in slot on side of trailer due to the screws at each edge so I just shifted the awning material in slot on roller to re-align.....then I installed a 1/4" screw in roller slot at edges of material.
Haven't had to re-align since
Thanks, I will check the roller slot and block it too if it isn't. If it is able to shift there then the problem could return. Unless the awning stretched, that would be how it got off kilter in the first place with the top held in place.
โAug-20-2014 08:28 AM
BFL13 wrote:
1. The Atwood propane stove had one burner that would not light anymore when turning the sparker on the left of the row of dials.
Took the top off the stove and found the three burners, a wire to each burner's own sparker to the main sparker dial (three wires). Swapped wires at the burner end, and now the bad burner worked and the other didn't. Hmmmm. Checked burner connection tubes, and orifices, all clear. Swapped wire sets between main sparker and burners, found that it was one of the three main sparker outlets that was the weak sister, wires ok.
Bought a new three- sparker gizmo ($29 Can.) that fits in there behind the dial you twist, installed using same wires, BAM! Each burner now fires up big on the first twist! Like magic. OK, so lesson is the sparker gizmo gets tired after 11 years, and you don't need a new stove top or whatever. ๐
โAug-20-2014 08:07 AM
โAug-20-2014 06:33 AM
Item #2
โAug-19-2014 11:11 PM
