Sbtuckmail's avatar
Sbtuckmail
AGS Thor 28A Where is the control module?
I have a 2024 Four Winds 28A.  There is an AGS button, but it does nothing.  Where is the control module located?  Thank you.
  • If I’m not mistaken, the AGS only starts the generator when power is needed. If power is currently being handled by the battery(s)/120v power system, the generator would not be needed and therefore the AGS would not start the gen.
    In any event, the module is probably located somewhere real close to the gen. It could be tucked up out of the way.
  • Look around in your compartments, perhaps mounted to the roof of one of the compartments or near the generator itself. Since this appears to be a new RV, you could simply call the dealer or ask Thor directly.
    • Sbtuckmail's avatar
      Sbtuckmail
      Thanks for all of the help.  I finally found the AGS - Thor 28A.  The module is located under a table seat in a screwed down compartment.  Basically all of the wiring is under the seat and AGS is mounted to the floor.  Same compartment with the fuse box.  However, apparently the sensor switch is bad and not functioning, so a warranty item I hope.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
