oldtrojan66
Sep 06, 2017Explorer
Aux power from truck to fifth wheel
Cannot find any positive results from search for this question.
How much voltage should be coming from the truck (when running) to the aux power "in" at the plug in?
I have a 2007 JAYCO 36 RLTS and a 2006 F350 dually. I believe the plug is factory and the pins are wired correctly. From 1 o'clock position to 7 o'clock position I read 11.67 VDC with truck running.
Seems that's not enough to provide even a trickle charge going down the road. Any thoughts?
Thanks in advance, david
