- Harvey51ExplorerIf it is stuck so the key can’t be turned while inserted in the lock, there is a workouround. With the key in, use vice grips on the lock to turn the whole lock. I did it with no damage to the lock but it is hard to get rid of the rust so better to replace it with a new one of the same size.
- sansouci2ExplorerWe will try that when it stops raining!! Thanks
- Tom_BarbExplorerpush in on the door as you try the latch.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
