BFL13
Jun 15, 2020Explorer II
I forget the math on this, if I ever knew it--when you add a panel to make up for can't be fixed shading loss, do you do better if in parallel?
In series the added panel is still going to be at the lowest amps same as the shaded panel; in parallel it could be more panel not in the shade so it does its full amount?
