rirish1
Dec 16, 2019Explorer
Battery/Converter Question
I want to take the battery out of my TT and connect it to a trickle charger for the winter. Is there any problem with leaving the TT plugged in without a load on the WCO converter?
wa8yxm wrote:
The ONLY caution I will give with that converter is this> Insulate the positive battery lead(s) if is just one wire attached to the positive put the cable end in something like an empty pill bottle and tape it to the cable so it does not come off.. If there are more than one tie them together (Bread tie or string) and .. A bigger pill bottle and tape it on. Make very sure it can not touch metal. Alternate is a short length of "Pool noodle" over the wire(s) to insulate them.
