Skid_Row_Joe's avatar
Skid_Row_Joe
Best sources for onboard water pump replacement?
My SHURflow 2093-204-413 water pump has failed after about 5 years. It quit suddenly - no warning.
The Green PUMP indicator light is illuminated when turning water pump to on, so, I'm assuming it's the water pump itself or why would it stop working?
Could a fuse be blown, and the Green PUMP light still be operable?
Was wondering if the diaphragm or what not internal part or filter could just be stuck?
BTW, all the wires are solidly connected. Checked that first thing.
Should I buy a new screw-on black plastic and clear flow filter also when ordering one?
  • Almot wrote:
    Skid Row Joe wrote:
    What's a DVM?? See above ^^^^ post. Water pump has green light indicating a complete circuit. Do you have a source for water pumps that you can recommend?
    DVM is the same as multimeter, for your purposes.
    Green light doesn't indicate proper voltage.
    There are "dozens" sources for RV parts. Just use Google. Here is one:
    PPL motor homes
    Was looking for the best/cheapest source for water pumps......
    The green light actually indicated a bad water pump in this case.
  • Almot's avatar
    Almot
    PPL motor homes
  • Skid Row Joe wrote:
    What's a DVM??
    DVM = Digital Volt Meter
    DMM = Digital Multi-Meter (measures more than just voltage)
  • The green indicator light is only telling you that the circuit was completed to the light bulb, not necessarily to the pump motor. I've found pumps at very favorable prices at Amazon. Not always the cheapest pump price, but with free shipping it beats the others.
  • Old-Biscuit wrote:
    Shurflo 2093 is a Whisper King model. Part of the Classic Series
    30psi discharge/ 2 gpm flow rate
    Whisper King info/parts break down
    Shurflo has 'discontinued' the Classic and Extreme Series
    Some 2093 pumps are still available from vendors old stock and replacement parts also.
    But if you should have to replace.
    Go with the 4008 Revolution Series.
    55psi and 3 gpm
    LINK
    There's a new application part # with the same GPM rating as before. Where have you sourced water pumps is what I'm down to now?
  • SoundGuy wrote:
    I wouldn't necessarily assume the pump itself has failed ... "green light" means nothing when we have no idea where in the circuit it's located. I sure wouldn't be buying a new pump until I knew for a fact that +/- 12 vdc was actually reaching the pump so the first step is to check with a DVM.
  • Almot wrote:
    This is not the kind of "green light" that one should trust or obey. Take a multimeter to pump and report back.
    I had my pump "failing", sort of. Motor running, no water flowing. Turned out to be debris in intake filter and air leak in the pump housing. It only needed cleaning and re-tightening.
    But, by all means, go ahead and buy if you think you have to, keep China happy.
    I don't know what is a "screw-on black plastic". If it's a hose fitting, and it's not broken, then disconnect and reuse it. Intake filter you remove, inspect and clean and again - if it's not broken, then reuse it.
    The green light indicates a completed circuit. The water pump isn't operating. The screw on black plastic with clear indicator viewer is on every water pump body - you cannot miss them.
  • Shurflo 2093 is a Whisper King model. Part of the Classic Series
    55psi and 3 gpm
    LINK
  • Almot's avatar
    Almot
  • I wouldn't necessarily assume the pump itself has failed ... "green light" means nothing when we have no idea where in the circuit it's located. I sure wouldn't be buying a new pump until I knew for a fact that +/- 12 vdc was actually reaching the pump so the first step is to check with a DVM.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
