Cummins12V98
Sep 11, 2019Explorer III
There is a tool to cut old pipe out of a ABS fitting. Don't think you want to spend that much $$$.
If you have a bad glued in valve simply buy the same open it up and remove the center slide portion and seals and install in old valve.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
