Son_of_Diablo's avatar
Mar 07, 2016
Black Tank Backflush plugged at tank connection
I cannot get my black tank back flush unplugged. I have the hose feeding the tank cut about 2 feet from the connection to the tank so I could connect a water supply. It is very difficult to reach the actual fitting entering the tank or I would have taken that apart. I connected water supply to the short hose but cannot get water to flow into the tank.
Question, is there a backflow device inside the black tank, if so how do I get it to open in order to clean the tank?
  • wa8yxm's avatar
    wa8yxm
    The answer depends on the flusher.
    Model: The Flusher: (yes that's a model) is nothing more than a sprinkler head, the backflow device is "up-line" from it and is a vacuum breaker that is mounted ASBOVE the top of the tank.
    Model: Tornado: Has a spring check vlave in the flush head itself.
    others: Vary.
    Recommendation: You must likely have one like "The Flusher" from the factory, Replace with Tornado, i did.
    Recommendation 2: I feed the Tornado via the original vacuum breaker, PLUS a 2nd Spring check and vacuum breaker on the supply hose.. Belt and Suspenders. 2 sets. Am I paranoid.... Well when I "Bult" the hose I did not knwo about the existing back flow preventers so no. Not that much.
    Oh, and I use a Quick Disconnect so when not flushing, Hose is disconnected (At the moment it is connected to a hand sprayer).
  • mine has an anti siphon valve located under the bathroom sink.
    i would check that before going any further.
  • Seems to me that there is a check valve (backflow preventer...anti siphon) located just inside the connection. It's usually cheap plastic and get hung up easily. I had mine replaced early on. One has to get to it from the outside by cutting away the sealant and removing the inlet plate.
  • Factory flush spray nozzles can be glued to tank OR they can be spun at high speed which melts plastic and 'welds' them to tank
    When holes in spray nozzle get clogged (usually from hard water minerals drying out inside nozzle) they are virtually useless.
    Now that you have hose cut off you could try filling hose with CLR and let it sit/soak
    If it is an aftermarket kit then spray nozzle will be installed using screws/sealant
    If you can't get to it to remove.....abandon in place and install new
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
