RobWNY's avatar
RobWNY
Breaker Panel Help Please
I was having an issue with my water heater not heating using Electric and discovered the entire right side of my breaker panel was off. I'm more than a little confused. I can't read what the first breaker says on each side of the Main breakers that starts with the letter "G" and I have a 15A breaker on the right side that has no label. I also don't have a Washing Machine but I'm guessing there's a breaker in place in case I install one at some point. I only have one Air Conditioner so why is there a breaker on each side of the Main? With the 12V area, can anyone decipher what No. 13 with the 10A fuse says? I'm adding a smaller version of the picture I took here but if you want to see the full size picture for better clarity, here is the link. Full Size Picture
