Chassis battery not charging
desertrver
We’re full timers currently connected to shore power. Coach batteries stay charged as normal. Chassis battery does not charge. With engine running, alternator charges normal. While engine is running, put battery tester on battery. Battery and charging system checks out normal. It appears coach converter/charger keeps coach batteries charged as normal, but isn’t keeping chassis battery charged. I’m a bit electrical challenged. Not sure how to trouble shoot.
11 REPLIES 11
Bobbo
Glad you got it diagnosed. Electrical problems can sometimes be very hard to track down.
Bobbo and Lin
desertrver
Follow up on chassis battery issue. Appreciate all the suggestions. I did take the advice to reread electrical systems section of owners manual. It states that some, like mine, Converter/ Chargers have a built in feature (Comparitor) that allows simultaneous charging of the House and chassis batteries. After talking with a tech that was at the National plant in Perris, it was determined the chassis battery was at fault. Replaced the battery and I’m back to normal. After several days sitting at campground chassis battery is holding charge as it always has for the past 16 years of full time in this MoHo.
pianotuna
Nomad II
Nomad II
Add a Trik-l-Start
Regards, Don
enblethen
ocate your battery control center. It may have a bi-direction charge relay setup. Gas rig in many coaches is located under the hood driver's side.If it does the relay could be bad or a fuse has blown.
Try to locate battery control center make and model and post.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rk911
desertrver wrote:
Thanks to all for the feedback.
We bought our 2004 National Sea Breeze new and have been living & Traveling full time since 2004 we’ve never had this issue before now.
what does your owner's manual say about this?
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
desertrver
Lwiddis
Consider a 30 watt or so solar system to maintain your chassis battery/batteries.
Bobbo
Read this thread. This is a current (pardon the pun) thread on solving exactly this problem.
Trickle Charging Chassis battery
Bobbo and Lin
BFL13
Nothing to trouble shoot. It is designed that way. To keep the engine battery on a Float charge, you need a separate charger for that, or parallel it with the house batts. Several ways to get it done, but normal problem.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
rk911
we've owned three motorhomes. the chassis batteries in each of them was not charged by plugging into shore power or running the genny. are you sure your MH is designed to charge the chassis battery that way?
we use this to keep the chassis battery charged when plugged into shore or running the genny.
Rich
'46 Willys CJ2A
'10 Jeep Liberty KK
enblethen
Make and model of coach?
Many converters do not charge chassis battery.
Bud
USAF Retired
Pace Arrow
